Jul 22nd, 2024, 11:25pm
mdl exception error!! (Read 2809 times)
topquark
Thames Valley, UK
Feb 07th, 2007, 2:23am
Hey guys,
MDL was running smooth 'n fine and all... now,I get a new 'exception error' since morning..
it goes like:
Error found by spectre during transient analysis `showVhys_td-004_showVhys_td',
       during task `MDLControl'.
   EXCEPTION: St9bad_alloc
Internal error found in spectre.  Please run `getSpectreFiles' or send the
       netlist, the spectre log file, the behavioral model files, and any
       other information that can help identify the problem to
       support@cadence.com.
   Assertion failed in file `msgHandler.c' at line 1650.
   Assertion failed.
Appreciate diagnosis of the above.
Thanks!
Gau
Scott Flinchbaugh
Re: mdl exception error!!
Reply #1 - Feb 8th, 2007, 7:37pm
Gau,
This is a memory error of some type that may or may not be MDL related.  It could also be caused by the
simulator.
In this particular case I would suggest contacting your field support person and filing a bug report with them.
-scott
View Profile flinchba   IP Logged
topquark
Thames Valley, UK
Reply #2 - Feb 9th, 2007, 6:08am
Yea, Scott- it's indeed a simulator error due to memory!
I was getting confused by the "MDL control" in the error message.
It was just a wrong "stop" parameter for the tran analysis.
Thanks for your time.
Gau
