Sep 15th, 2026, 7:08pm
AMS simulation error (Read 3188 times)
rajdeep
UK
Feb 07th, 2007, 5:09am
I am getting this error while running AMS simulator.
Failed to read "/home3/rajdeep/simulation/lp3918_top_test/ams/config/netlist/netlistHeader"
I have checked to see that no such file was created in that path!!  But the directory 'netlist' was created. I
Can anybody suggest what can be the possible reasons??
I have moved to ams simulator because I was getting error in spectreVerilog due to the presence of some bidirectional nets.
Now, ans simulator is  giving this error.
PLEASE HELP!!!
Rajdeep
rajdeep
UK
Re: AMS simulation error
Reply #1 - Feb 7th, 2007, 10:23am
Can anybody tell me how to set up the ams simulator??
May be I'm doing some mistake in the ams setup.  I was trying to run a simple invverter, having verilog view.
Here is how I set up the config  view:
Hierarchy Editor -> Write Schematic in the field View (name of the window is New Configuration) -> Choose AMS in Use Template
What I see after this is:
Library List: basic analogLib
View List: verilogams veriloga behavioral functional schematic symbol
Stop List: Symbol
Don't know why it does not choose verilog for the inverter!!!
As  expected it gave an error saying..
*Error* <ACE setSimParams>  Failed to read  /home3/rajdeep/simulation/inv_test/ams/config/netlist/netlistHeader"
AM I MISSING SOMETHING IN THE SET UP?
Rajdeep Undecided
Reply #2 - Feb 7th, 2007, 4:02pm
You've not really given much to go on. My guess is that there are other errors being given too?
You say that it does not choose verilog for the inverter - how do you know that? What views are present under the inverter?
Start off by working through the tutorial in the AMS Documentation - that's a good start.
rajdeep
UK
Reply #3 - Feb 7th, 2007, 9:02pm
Hi Andrew!!
" You say that it does not choose verilog for the inverter - how do you know that? What views are present under the inverter? "
3 views are available for the inverter..layout, symbol, verilog.
Well, in the hierarchy editor I have seen it choosing the symbol view for the inverter. That's how I know.
Is ther a great deal of difference between setting up spectreVerilog and AMS?
Where can I get the AMS documentation?
Rajdeep
Embarrassed
zhong
California , United States
Reply #4 - Feb 8th, 2007, 12:27am
If you want AMS to  take the inv verilog view.  In HED you need to bind the inv to verilog view instead symbol view .
The AMS setup is different than Spectre-Verilog.  I would suggest you to read the User Guild from cdsdoc. Also the built-in tutorial is helpful . You can use the tutorial under
CIC_hier/tools/dfII/samples/AMS/
as a starting point to learn AMS ...
zhong
Reply #5 - Feb 8th, 2007, 11:14am
rajdeep wrote on Feb 7th, 2007, 10:23am:
Stop List: Symbol
You do not have verilog in the view list, so the only view that it will pick automatically will be symbol. So you have two choices - either add verilog into the view list (in front of symbol), or go over the view name for the inverter cell and use right mouse->view to use, and pick verilog.
Using the hierarchy editor for view selection is the same regardless of whether you are using SpectreVerilog or AMS.
rajdeep
UK
Reply #6 - Feb 8th, 2007, 10:32pm
Hi Andrew,
I have done exactly what you told, but the error remained same.
I think there is some settings problem. I'm not sure.
I wonder what is this <ACE_setSimParams> mean?? This can give me a hint to the problem..
Rajdeep
Reply #7 - Apr 20th, 2007, 1:01am
That ACE error looks to me like something coming from a Nat Semi flow. I've seen this before:
     \o <ACE> Adding Spectre flowchart step "ACE_setSimParams"
and so I believe it is a local customisation to the spectre flow. Please check with the supplier of your design environment.
