Jul 22nd, 2024, 11:24am
Cadence Corner Analysis Tool (Read 6218 times)
Visjnoe
Feb 09th, 2007, 2:21am
Dear all,
I experience problems when I set up a corner analysis using ADE and then export it to an OCEAN script
(or even without exporting it).
Basically, in the OCEAN script there's a statement like this:
corSetMeasExpression( "ton" "(cross(VT(\"/up\") 0.9 -1 'falling) - cross(VT(\"/up\") 0.9 -1 'rising))" )
Of course, for corner analysis, I would like to replace the fixed 0.9 by Vdd/2.
Vdd is certainly a parameter of my netlist and added to my corner setup file .pcf.
When I replace the above code by the following:
corSetMeasExpression( "ton" "(cross(VT(\"/up\") "Vdd/2" -1 'falling) - cross(VT(\"/up\") "Vdd/2" -1 'rising))" )
my OCEAN corner script is not able to output these results over corners. Furthermore, the corner analysis GUI
reacts in the same way (only a fixed number works...)
Has anyone a solution for this? I can't imagine this cannot be setup under Cadence...
Kind Regards
Peter
ACWWong
Oxford, UK
Re: Cadence Corner Analysis Tool
Reply #1 - Feb 9th, 2007, 2:30am
try VAR("Vdd")/2 instead of 0.9
Visjnoe
Reply #2 - Feb 9th, 2007, 5:24am
Dear ACWong,
thanks for your reply.
Is there anywhere in the documentation this is mentioned? I went through all relevant manuals/user guides and could not find anything...
Kind Regards
Peter
Visjnoe
Reply #3 - Feb 9th, 2007, 5:38am
Dear,
the VAR("Vdd")/2 suggestion does not seem to work...
Kind Regards
Peter
Visjnoe
Reply #4 - Feb 9th, 2007, 5:46am
Dear ACWong,
my mistake, it DOES work, it is just case sensitive.
Any pointer to the relevant piece of documentation would be welcome!
Kind Regards
Peter
ACWWong
Oxford, UK
Reply #5 - Feb 9th, 2007, 6:12am
VAR is a calculator function, try looking for in skartisitref.pdf (ADE Skill reference) or calculator/wavescan userguides.
I haven't oceaned for a while, but i seem to recall using desVAR does the same thing ?
Reply #6 - Feb 22nd, 2007, 12:05pm
No, desVar() would not be used inside an expression like this. desVar() is for setting and retrieving design variables in OCEAN. VAR() is for accessing the value of a design variable (or swept design variable) in an output expression in a parametric or corner sweep.
