Jul 2nd, 2025, 5:33am
random PWM (Read 1012 times)
trond
Glasgow, Scotland
random PWM
Feb 13th, 2007, 11:11pm
I am trying to generate a signal with constant period, T, but random duty-cycle. Essentially, I would like to obtain a clk-like signal whose "on-time" is random and uniformly distributed between 0 and let's say 0.1T.
I can generate random bit streams with:
@(timer(start, period))
x = ($random(y) >= 0) ? 1 : 0;
but here the period of the signal x will vary and also I cannot set limits on the duty cycle maximum and minimum.
Can anyone suggest a way?
Thanks for any tips.
trond
Glasgow, Scotland
Re: random PWM
Reply #1 - Feb 14th, 2007, 12:01am
I ended up generating a tri-wave with period T and height 1. This i did with using the idtmod function.
Also I generate a random amplitude signal with period T using
@(timer(0.0, T)) x=$rdist_uniform(seed, 0 ,1 ) % 0.1;
Then my desired random duty-cycle signal with constant period T, and in this case,  on-time between 0 and 0.1T is generated by:
@(cross(tri - 0.5, -1) or cross(tri - x, +1))  n=(tri >=0) && (tri < rand);
This works fine.
Still, is there an easier way?
Re: random PWM
Reply #2 - Feb 22nd, 2007, 11:19am
Here's something I wrote a while ago for testing an eye diagram calculator function. Not quite what you want, but it might give you a few clues:
// VerilogA for test, randedges, veriloga
`include "constants.h"
`include "discipline.h"
module randedges (op);
output op;
electrical op;
parameter real period = 50.0n from (0:inf);
parameter real sd = 1.0n;
parameter real vh=5.0;
parameter real vl=0.0;
parameter real tdel=10.0n from [0:period);
parameter real trise=2.0n from [0:period);
parameter real tfall=2.0n from [0:period);
parameter integer seed = 23133;
integer cycle,bit,vseed;
real next,vout_val,randnum;
  analog begin
   @(initial_step("ac","tran","dc","xf" )) begin
	vseed=seed;
	cycle=1;
	next = cycle*period/2.0;
	bit=0;
	vout_val=vl;
    $bound_step(period/4.0);
    @ (timer(next)) begin
	bit=~bit;
	cycle=cycle+1;
	vout_val=(bit==0 ? vl : vh);
	//randnum=($rdist_normal(vseed,0,1))*sd;
	randnum=$rdist_normal(vseed,0,1);
	randnum=randnum*sd;
	//$display ("Random number is %g sd is %g", randnum,sd ) ;
	next = cycle*period/2.0+randnum;
	//$display("Current: %g next: %g rand %g cycle %d",$abstime,next,randnum,cycle);
    V(op) <+ transition(vout_val,tdel,trise,tfall);
jbdavid
Re: random PWM
Reply #3 - Mar 17th, 2007, 5:11pm
you do one timer for the rising edge
@timer(start,period) begin
duty = period*rnd(0->1); <- multiply period by a random number between 0 and 1
signal = 1
timeout = abstime+duty
and another for the falling edge,
@timer(timeout) signal = 0;
- untested and not legal syntax, but it seems easier than generating extra signals
jbdavid
