Jul 22nd, 2024, 5:17pm
calling  hspice from analog artist (Read 1891 times)
jobless
India
Feb 17th, 2007, 6:38am
I want to run hspice from Cadence Analog Arist. Where do I set the environment variables for hspice? (like the license server ip address and hspice path).
My ADE version is 5.0.33
tnx.
Re: calling  hspice from analog artist
Reply #1 - Feb 22nd, 2007, 11:34am
Well, the Cadence tools only care about you having the hspice executable on your UNIX path (set using the $path variable in csh, or $PATH environment variable in sh/ksh/bash). As for the licensing, you'd set that up the same way for hspice as if you were running hspice standalone (you  could set $LM_LICENSE_FILE - or there may be a Synopsys specific variable that controls hspice licensing, I don't know).
