Jul 21st, 2024, 7:23pm
Need Spectre Help on initial values (Read 5955 times)
kiran123
Feb 21st, 2007, 6:03am
Hi Experts,
 Can anyone of you tell us on how to give an initial condition for vsource/isource  or any passive components in spectre ? because i wanted in one senario where i initially wnated to force some voltage and current value at some nodes and then do a DC analysis with the existing DC sources which i declared in body of simulation deck.
by the way is there any possibility of giving stimulus of pulse type with specified format say "1001110" where i can define pulsewith of pulse and tr and tf
i can do this with pwl but the definiing will be very lengthy when it comes to long 1's and 0's format
Thanks for your support
Best Regards
Kiran Kumar
Re: Need Spectre Help on initial values
Reply #1 - Feb 22nd, 2007, 11:49am
An initial condition for a vsource or isource is rather meaningless - it's implicitly defined by the source itself.
For capacitors and inductors you can specify an initial voltage or or current (see "spectre -h capacitor" or "spectre -h inductor" and look at the ic parameter). Alternatively you can use spectre's nodeset or ic statement (spectre -h nodeset or spectre -h ic) to do this kind of thing on particular nodes (say).
As for the bit type stimulus, you can do that:
vsource (1 0) vsource type=bit val0=0 val1=1 rise=1n fall=1n period=10n data="101100101"
r1 (1 0) resistor r=1k
tran tran stop=150n
achim.graupner
Reply #2 - Feb 25th, 2007, 11:39pm
Dear Kiran,
as regards your 2nd question "0101..." the best thing is to use a verilogA-Model. If you have a discrete timing you can use the
always @ (timer())-Statement to write a variable and the
transistion-Statement to drive the output. If this description is to short for you. please let me know, I will look for an example for you.
Another possibility is to (automatically) create a VerilogA-Modell from the .vcd-output of a digital simulator. This is helpful if the required waveforms are complicated and do not change between different analog simulations. I have a script available which does this conversion. I can provode it if you like.
Achim
Achim Graupner
ZMD AG, Dresden, Silicon Saxony, Germany
kiran123
Reply #3 - Feb 27th, 2007, 6:58am
Achim,
      if there is another way declaraion, Yes, i would like more explanation on defining that
So could please expalin me on how to define with an example how Mr.Andrew suggested
Best Regards
Kiran Kumar
kiran123
Reply #4 - Mar 13th, 2007, 6:29am
Andrew,
       Thanks for your reply but when used the same statement i am getting error message as shown below
could you please let me know what needs to be done . One thing is i remember this is SPICE format of declaration so it would be helpful if you tell me what modification should i do to suppress this error
Notice from spectre during hierarchy flattening.
   vsource: Invalid enumeration `bit' used as value of parameter `type'.  Ignored.
Error found by spectre during hierarchy flattening.
   vsource: Waveform type must be specified if any waveform parameters are given.
spectre terminated prematurely due to fatal error.
Thanks & Best Regards
Kiran Kumar
Reply #5 - Mar 13th, 2007, 7:34am
Kiran -
I think you need a newer version of the simulator.  I see "bit" is not available in IC5.1, but is available in MMSIM6.1.  Andrew can probably tell you which exact version it was added in.
Reply #6 - Mar 15th, 2007, 6:34am
It was added in MMSIM6.1 as Geoffrey suggested.
Note, it's not currently a choice in the analogLib vsource/isource/port components - PCR (Product Change Request) 952356 has been filed to get that implemented.
