Jul 16th, 2024, 11:31pm
Debugging Analog Erros in Spectre-NCSIM (Read 5903 times)
badamsssl
Feb 26th, 2007, 7:32pm
Hi
I was trying to model some transistor level circuits in VHDL AMS using Cadence Spectre VHDLAMS.
I have no clue in how to debug the
"Error found by spectre during DC solution estimation, during IC analysis,
       during transient analysis `amsAnalysis'.
   Matrix is singular (detected at `tb_output' and `uInv.A1.irn').
ncsim:*E, RNALER: simulation terminated due to analog error"
Thanks in advance. your help is awaited.
Re: Debugging Analog Erros in Spectre-NCSIM
Reply #1 - Mar 27th, 2009, 11:26am
Look for floating nodes, particularly `tb_output' and `uInv.A1.irn'. Once you find them, add a large value resistor from that node to ground.
