Spectre's info analysis can output a captab. From
spectre -h info:
Code:1 what=oppoint What parameters should be printed. Possible values
are none, inst, models, input, output, nodes, all,
terminals, oppoint, captab, parameters, primitives,
subckts, assert, or allparameters.
Captab parameters
9 detail=node How detailed should the capacitance table be.
Possible values are node, nodetoground or
nodetonode.
10 sort=name How to sort the capacitance table. Possible values
are name or value.
11 threshold=0 F Threshold value for printing capacitances (ignore
capacitances smaller than this value).
So:
Code:captab info what=captab where=file
In ADE, you can access this from the Options form on the DC analysis. There's a checkbox labelled "captab", and when enabled you can then set the other parameters listed above. Enable the DC operating point, and run the simulation. Some output appears in the log, but you can also do Results->Print->Capacitance Table afterwards.
in your netlist would do it. There's also
