Jul 17th, 2024, 4:34am
spectre vs hspice (Read 234 times)
thlcak
spectre vs hspice
Mar 02nd, 2007, 12:24pm
I've been using hspice all my career.  I read posts here and most designers are using spectre.
Is spectre for analog, RF circuit design?
Re: spectre vs hspice
Reply #1 - Mar 3rd, 2007, 2:06am
Absolutely.
For a high level view, you can look at the datasheet, on http://www.cadence.com/products/custom_ic/spectre/index.aspx, but you might also want to look at Ken's book http://www.designers-guide.org/Books/dg-spice/index.html
simon2
Southampton, United Kingdom.
Reply #2 - Sep 20th, 2007, 4:13pm
Hi thlcak,
             like you I have used Hspice a long time - so long in fact I forgot how whilst using spectre for 12 years, then I had a chance to return to Hspice after becoming Spectre-centric via advice, celerity, eldo, pspice then more recently winspice.
For what it is worth, in terms of producing reliable, believable results most easily I would rate the tools thus: Hspice, Eldo, WinSPICE, Pspice, then trailing by a long way, Spectre.  (Sorry Andrew, I know you are a great proponent of Spectre ...).
The reason I say this is that it seems that spectre is good at what it does, which is to provide an analogue interface into the Cadence tool suite and as such is intended (and may be the only) tool which can be used across multi-national, multi-site, multi-discipline teams.  And it does that well.
What spectre does not well do is address what we analogue designers really need: to be able to directly and simply (and I stress simply as it often takes two days to work out how to do in spectre-cadence what can be done in hspice or WinSPICE in two or three minutes) and that is to access all of a device instance's parameters and to be able to manipulate them.  I won't comment on how poor the scripting capabilities of spectre really are as I am likely to get sued!
Speaking from many hundreds of hours spent sorting out the issues for all of the above tools, I would say that on balance, stick with hspice, its results are far more accurate, despite supposedly using the same model files!
Remember Hspice is still the "gold standard" for the foundries, who at the end of the day underwrite the accuracy of the designs we do.
Perhaps my last comment could be that as a small company on a limited budget where these tools directly effect our "bottom-line" we have chosen to invested in Hspice, not Spectre.
- Hope my opinions haven't offended anyone; they are personal, but have been formed from years of practical (and pragmatic) experience of using the tools "in anger".
Cheers,
            SimonH.
Simon.Harpham@ieee.org
http://www.SiliconDevices.com
Reply #3 - May 16th, 2009, 11:33pm
I'm not offended, but I suspect that you may be unaware of much of spectre's capabilities. It is possible to manipulate device parameters (very easy in SpectreMDL, for example), and you can access all operating point data very easily with wildcards these days.
You can either use SpectreMDL, OCEAN, or VerilogA for performing most of the "scripting" tasks you're likely to need. What you said wasn't very specific, but I'd be surprised if there are things you can do in hspice that you can't do just as easily (if not more easily) with spectre.
Whilst I'm clearly biased by virtue of working for Cadence, I have used multiple simulators as a designer over many years, and I would have no hesitation to using spectre if I was a designer again and no longer working for Cadence.
I'd be interested in hearing more specifics as to what you think spectre's failings are - if they really are failings, we can then fix them!
Berti
Reply #4 - May 19th, 2009, 3:48am
Hi Andrew,  SimonH,
Despite you having different opinions are you in agreement which simulator is faster? Spice or spectre? (for spice it probably depends on the actual tool)
Cheers
Reply #5 - May 19th, 2009, 5:07am
Faster??  Ultrasim or nanosim are "faster" but Ken's put them in the "timing simulator" section of this forum because they're not as accurate.
If you really want a fast spice simulator, you might need to look at BDA (there are some postings on this forum), or Cadence's Spectre Turbo or APS.  I'm not familiar with Synopsys' offerings in this space, nor its multithreading capabilities.
