zhong
California , United States
Let's say your digital lib is mylib_3v and you want to define the discipline "logic3v0" for whole cells under this lib , you can add following in your ncelab command
ncelab -scope_discipline "lib-mylib_3v- logic3v0" .....
Instead of define cell by cell or instance by instance ... This allows you to define customerized discipline in one-shot for whole lib
BTW, you can also use AMS-ADE to define discipline on lib/cell/cell-term/instance-term/net via Composer. In order to do that , 1. Choose ams simulator in ADE 2. After step 1, Composer will show "AMS" in the tool bar 3. Composer -> Tool bar "AMS" -> Default Disciplines Selection -> Library ...
Hope this helps ..
Zhong
