Aug 15th, 2024, 10:41am
Load and save command in spectre? (Read 1688 times)
Amit Singh
Mar 11th, 2007, 4:39am
  I am facing problem ragarding the long simulation time of the closed loop of CDR. It takes several hours for one run of the closed loop to get stable i.e control voltage to stabilise. In some simulator there are load and save commands to save stable node voltages after some time and then they can be used in other simulations.
  I am not aware if  this feature is available in spectre. If there is a way to do this please let me know the proceedure.
Re: Load and save command in spectre?
Reply #1 - Mar 15th, 2007, 6:48am
From spectre -h tran:
15	saveperiod	  Save the tran analysis periodically on the simulation
				  time.
16	saveclock=1800 s  Save the tran analysis periodically on the wall clock
				  time.
17	savetime=[...]    Save the analysis states into files on the specified
				  time points.
18	savefile	    Save the analysis states into the specified file.
19	recover	     Specify the file to be restored.
