Amit Singh
Hi, I am facing problem ragarding the long simulation time of the closed loop of CDR. It takes several hours for one run of the closed loop to get stable i.e control voltage to stabilise. In some simulator there are load and save commands to save stable node voltages after some time and then they can be used in other simulations. I am not aware if this feature is available in spectre. If there is a way to do this please let me know the proceedure.
