Jul 21st, 2024, 3:16pm
how to measure the THD of sample and hold circuit (Read 144 times)
manisms
Mar 15th, 2007, 12:14am
how i calculate the THD of sample and hold circuits  in cadence tool
actually the normal procedure as the select the net and take special function of THD and then plot .
but this is ok with the continuous wave and any amp.
but here the input signal is getting sampled at every clock cycle.
so i need to calculate the THD ...in this regards.
and please tell me how to measure the gain error and nonlinearity and pedestal error of s/h circuit in cadence ..
and docs for test benchs available plese please send to me..
i will be really obliged ..
regards
vivkr
Re: how to measure the THD of sample and hold circ
Reply #1 - Mar 15th, 2007, 6:22am
I would recommend using the strobe feature of transient analysis to begin with. This guarantees that the simulator
places a timestep at the point where you want to observe the sampled output. Without this, you are likely to get
very bad results. After this, you can use the inbuilt "dft" function of the calculator.
However, this feature which used to work well earlier seems to give me some trouble nowadays. So, I print out
the output values into a text file at the strobed points, and perform an FFT with any convenient tool - MATLAB,
Excel etc. Normally though, the calculator should do a good job if you have properly strobed the output at the right
point.
Vivek
Reply #2 - Mar 15th, 2007, 6:24am
PSS or QPSS (depending on the frequency relationship) is how I'd do this.
See http://www.designers-guide.org/Analysis/sc-filters.pdf
manisms
Reply #3 - Mar 17th, 2007, 8:18am
hi VVkr
thanz for reply ..
as i am not very use to this cadence tool.
my question is that when i havea strobed the output of my s/h in transient analysis and  run my simulation.
then after running  the simulation if i plot the output it will show me the result of output where i strobed the signa.
then after that what i will do means how i proceed to calculate the thd .
i want to  know the procedure of which net i click and choose the dft funtion in calculator.
please  tell me how i proceed as i am very new for this tool.
hope u will help .
regards
manish
