Jul 20th, 2024, 11:36pm
Why does substrate current so large?? (Read 2556 times)
zhangjerome
Mar 18th, 2007, 8:33pm
I am now designing a CML D latch biased with cascoded current source. With transient simulation, the drain current and source current of the common-gate transistor in the current source differs from each other by about 400uA. I checked the node current and found out that the current goes to B node.
The substrate of the transistor is grounded, and the transistor is in active region. I totally have no idea how
this coulde happen.
Is this a model problem or simulation problem? Or there is something wrong with my circuit??
Thanks, bow~~
Re: Why does substrate current so large??
Reply #1 - Mar 19th, 2007, 4:17am
Can you run a dc sweep across the active operating region, corresponding to the operating point of the transient?  You should use this to determine if the current is dc (caused by impact ionization -- or dc diode current, if you have a pmos where you thought you had an nmos because of a severe modeling problem) or if the current is capacitive (s/b or d/b diode capacitances charging/discharging during transient might cause a "glitch" in current -- how long does the large body current persist?).
zhangjerome
Reply #2 - Apr 9th, 2007, 6:55am
Geoffrey_Coram wrote on Mar 19th, 2007, 4:17am:
Thank you. I now know that it's bacause of the large voltage swing at the drain node and the current is capacitve.
