badamsssl
HI could you please help me overcoming the following problem while simulating a Behavioral Charge Controlled model developed in VHDL AMS through an inverter:
Error found by spectre during DC solution estimation, during IC analysis, during transient analysis `amsAnalysis'. There were 7 attempts to find the DC solution. In 13 of those attempts, a signal exceeded the blowup limit of it's quantity. The last signal that failed is U(uInv.A1.qIn) = -1.80144 G, for which the quantity is `U' and the blowup limit is (1 G). It is possible that the circuit has no DC solution. If you really want signals this large, set the `blowup' parameter of this quantity to a larger value.
Thanks in Advance --Srinivas
