Jul 22nd, 2024, 5:25pm
Transient Noise in Spectre (Read 5813 times)
badminton
Mar 21st, 2007, 8:04pm
Hello all,
  I am designing a low-jitter clock buffer.  For jitter simulation I plan to use the transient noise simulation feature in spectre.  However, I am not very sure how to set the various settings (noiseseed, noisefmax, noisescale, etc.) to obtain a sufficiently accurate simulation of jitter, while minimizing simulation time.  Can anyone give me some pointers?  Thanks!
Sincerely,
Badminton
Michiel
Enschede, the Netherlands
Re: Transient Noise in Spectre
Reply #1 - Mar 22nd, 2007, 4:09pm
badminton wrote on Mar 21st, 2007, 8:04pm:
Hello all,
Sincerely,
Badminton
I would advise to gain some familiarity with the simulation first. You can start with a simple circuit like an inverter.
-the value of noiseseed is of little importance. Just set it to one.
-set noisefmax to a frequency that is significantly higher than the bandwidth of interest. For a first test you could use 10G
-if you trust your model parameters, set noisescale to one
badminton
Reply #2 - Apr 24th, 2007, 10:54pm
Thanks for the tips.
I have some other questions about transient noise simulations:
1.  How do the transient noise waveforms compare with the waveforms measured on an actual circuit?  In other words, how much can we trust transient noise simulations?
2.  How exactly is spectre simulating transient noise?
Reply #3 - Apr 25th, 2007, 3:40am
badminton wrote on Apr 24th, 2007, 10:54pm:
I think there's a whitepaper on this on SourceLink.
venki_vlsi
warangal
Reply #4 - May 16th, 2007, 9:30pm
hi,
Can u plz send link of that paper.
where is source link?i dint get it.
plz help me.
s.venkat_nitw
Reply #5 - May 17th, 2007, 4:10am
http://sourcelink.cadence.com
You need to register (meaning, I think, you need to be a Cadence customer.)
