trond
I wanted to implement a quick 2 second order CIC decimation filter based on the cascade of two accumulators, followed by a rate reduction by M, followed by two differentiators. The input to the decimator is the one bit output of a Sigma Delta modulator, i.e. 0,1,1,0,0,0,1......
This is was i am using:
\\INTEGRATORS @(cross(V(clk) -0.5 , 1)) begin //Fast clk accum1=accum1+sd_output; accum2=accum2+accum1; end
\\RE-SAMPLE @(cross(V(clkM) -0.5 , 1)) begin //Decimated clk x1=accum2;
\\DIFFERENTIATORS d1=x1 - absdelay(x1, 4/Fs); d2=d1 - absdelay(d1, 4/Fs);
Then I read out d2 and save to a file for processing in Matlab.
Now, this works fine BUT, the integrator registers will get quite large. So i wanted to use modulo arithmetic by using:
\\INTEGRATORS @(cross(V(clk) -0.5 , 1)) begin //Fast clk accum1=(accum1+sd_output) % 1024; accum2=(accum2+accum1) % 1024; end
But there must be something wrong as the final output does not contain my signal anymore. How does one do two's complement or modulo N arithmetic in VerligA\MS???/
thanks for any tips.
