Aug 3rd, 2024, 1:21am
zero diagonal found in Jacobian. (Read 17434 times)
senyou78
germany
Mar 25th, 2007, 6:31am
hi,
I am coding in VerilogA and I want switched capacitor model for resistor. But capacitor is behaving very ackwardly. And when i simulate then i get zero diagonal found Jacobian. Codes for switch and capacitor are geiven . Used software is cadence.
// VerilogA  switch, veriloga
`include "constants.vams"
`include "disciplines.vams"
module switch(pc,nc,p,c);
input pc , nc;
output p , c;
electrical pc,nc,p,n;
parameter real vth =0.6;
parameter real dir = +1  from [-1:1] exclude 0;
analog begin
 @(cross(V(pc,nc)-vth, dir));
  if(V(pc,nc) > vth)
            V(p,n) <+ 0;
 else
        I(p,n) <+ 0;
/ VerilogA for  Ca, veriloga
module C(p, n);
inout p, n;
electrical p, n;
parameter real c=1 from (0:inf);
analog begin
   I(p,n) <+ c*ddt(V(p,n));
help would be highly appreciated.
Re: zero diagonal found in Jacobian.
Reply #1 - Apr 2nd, 2007, 6:25am
senyou78 wrote on Mar 25th, 2007, 6:31am:
Your capacitor looks fine to me; I suspect the switch is what's really giving you trouble.  In some simulators, it's better to explicitly declare two branches when you want a switch:
 input pc , nc;
 inout p, n;
 branch (p, n) zeroi, zerov;
 analog begin
     ; // for timestep control
   if(V(pc,nc) > vth)
     V(zerov) <+ 0;
   else
     I(zeroi) <+ 0;
Reply #2 - Apr 2nd, 2007, 6:26am
This post probably should have been in "Verilog-AMS"
Reply #3 - Apr 2nd, 2007, 7:19am
This problem is most likely caused by a switch opening up and leaving no path to ground.
Your models look okay, but be aware that connecting ideal switches to capacitors can cause a lot of trouble in the simulator as it tends to also create infinite current pulses.
senyou78
germany
Reply #4 - Apr 5th, 2007, 2:24pm
thanks for answering. Smiley
senyou78
jovial
Reply #5 - Jun 27th, 2013, 9:54pm
Geoffrey_Coram wrote on Apr 2nd, 2007, 6:25am:
 input pc , nc;
 inout p, n;
 analog begin
   if(V(pc,nc) > vth)
     V(zerov) <+ 0;
   else
     I(zeroi) <+ 0;
Dear Geoffrey,
I tried to use ur code as an ideal switch.
This gives the following error-
"FATAL: The following branches form a loop of rigid branches (shorts) when added to the circuit:
       V1:p (from vin to 0)
       I21:out_flow (from net2 to 0)"
Cn u plz suggest me how to solve this problem.??
boe
Reply #6 - Jul 1st, 2013, 1:43am
jovial wrote on Jun 27th, 2013, 9:54pm:
You have shorted two voltage sources.
- B O E
boe
Reply #7 - Jul 1st, 2013, 1:44am
Geoffrey,
IMO, the switch model should use a cross event for both directions.
- B O E
Reply #8 - Aug 2nd, 2013, 8:58am
Six years later, someone's looking at this old code ...  Yes, B O E, I agree that the cross event should test both directions, but it appears this was in the original model.
boe
Reply #9 - Aug 9th, 2013, 1:59am
jovial,
A search would have given you http://www.designers-guide.org/Forum/YaBB.pl?num=1177054990
- B O E
PS: @Geoffrey: yes, it seems the original model already included the bug.
