Aug 15th, 2024, 12:39pm
Can VerilogA input Hexadecimal number? (Read 2808 times)
seefree
Mar 28th, 2007, 1:04pm
for example, define a parameter as hex format, user input "F", the output is "15".
ACWWong
Oxford, UK
Re: Can VerilogA input Hexadecimal number?
Reply #1 - Mar 29th, 2007, 2:32am
no, i don't think verilogA can do this (although you can output in hex format using $strobe etc.). Try looking at the verilogA reference manual in your installation path.
on the other hand verilogAMS should (?) be able to handle integer types which are hex....
cheers,
aw
seefree
Reply #2 - Mar 29th, 2007, 5:49am
Thanks! You confirmed my doubt.
