Jul 20th, 2024, 2:34am
switched-capacitor simulation problem (Read 5962 times)
zhujun134
Apr 02nd, 2007, 11:26pm
hi,all expert,
   i meet some problem when i simulate the switched-capacitor circiut,i don't know whether i need  to use port as the stimulus?
i have used port and vdc as the stimulus,and keeping the same parameters,but i get the different result!i am puzzle!may you get me some advice! and i want to know the difference between the vsin(vdc..) and the port!
  Must i use the port as the stimulus in sc-circiut?
 thanks!
View Profile 88206995   IP Logged
Re: switched-capacitor simulation problem
Reply #1 - Apr 2nd, 2007, 11:32pm
spectre -h port
zhujun134
Reply #2 - Apr 2nd, 2007, 11:49pm
kundert,
thanks your replay!
i can not get your mean well,do you want me type "spectre -h port "in the CIW?
and do i have to use the port as the stimulus when i simulate sc circiut?
Reply #3 - Apr 3rd, 2007, 7:40am
No, type
 spectre -h port
at the Unix command prompt.  (Hopefully, spectre will be in your path ...)
zhujun134
Reply #4 - Apr 3rd, 2007, 8:49pm
Thanks!
I have got it!
Reply #5 - Apr 11th, 2007, 7:56am
No, you don't have to use a port when simulating a Switch Capacitor circuit. You can use a voltage source (vsource) or current source (isource) - whatever is the most appropriate for your needs.
It's a common misperception that SpectreRF analyses require you to use ports; they don't. You need ports for s-parameter analyses, and for measuring noise figure (because these include a noise source as a result of the port impedance). They're also useful if you want to specify a signal level as a power, since they are a voltage source with an in-built resistor, but apart from that you can use any source with any analysis.
zhujun134
Reply #6 - May 14th, 2007, 7:01am
Andrew,
          Thanks for your replay and advice!
         I don`t get less parameter when i use vsourse than using port?is it a right result for me?
zhujun134
Reply #7 - Aug 27th, 2007, 2:38pm
zhujun134,
Sorry for the very delayed reply (I've got rather behind with Designer's Guide recently and madly trying to catch up now!). Anyway, I don't understand your question...
