Jul 16th, 2024, 6:31pm
error when adding 2 variables (Read 2164 times)
Pavel
Lausanne/Switzerland
Apr 17th, 2007, 12:29am
When modelizing fully differential OTA I've met strange error from veriloga parser.
Here are 2 variables that modelize output small-signal behavior
	V1P_AC = Gain_AC * laplace_nd(vin_dif,  zeros, poles);
	V1N_AC = Gain_AC * laplace_nd(-vin_dif, zeros, poles);
and here is common mode processing
V1_CM  = Gain_CM * laplace_nd(V(Vbpfb), zeros, poles);
Then I add common-mode part with small signal part to form outputs:
	V1P = V1P_AC + V1_CM;
	V1N = V1N_AC + V1_CM;
When I compile this code, following error appears:
Error: dynamic quantities must be directly accessible to the outputs.
What does this error mean?
Pavel.
Pavel
Re: error when adding 2 variables
Reply #1 - Apr 17th, 2007, 12:40am
Sorry, the error message concerns portion of code that follows:
// Slew-Rate processing
	@(above(SLEW_RATE - ddt(V1P))) slew_rate_P = 0;
	@(above(SLEW_RATE - ddt(V1N))) slew_rate_N = 0;
	@(above(-SLEW_RATE + ddt(V1P))) begin
		slew_rate_P = 1;
		i_max_P = I(OutP);
	@(above(-SLEW_RATE + ddt(V1N))) begin
		slew_rate_N = 1;
		i_max_N = I(OutN);
Pavel
Pavel
Reply #2 - Apr 17th, 2007, 1:04am
Resolved - for slew rate processing I employed slew function.
Pavel
