Jul 16th, 2024, 6:23pm
parameter array declaration error (Read 194 times)
Pavel
Lausanne/Switzerland
Apr 17th, 2007, 5:04am
Hello
In my code I try to use the similar instruction as in example in chapter 3.2.3 "Parameter arrays" of Verilog-AMS
Language Reference Manual
parameter real fpoles [0:4] = {5.727, 1.24E+07, 1.84E+07, 2.38E+07, -3.57E+07};
The parser gives the following error message:
In Affirma-AMS, parameter array declaration is not supported.
Where am I wrong?
Pavel
Re: parameter array declaration error
Reply #1 - Apr 17th, 2007, 6:52am
Parameter arrays are not supported in Verilog 1364-2005 (they are in SystemVerilog 1800-2005), so your AMS simulator may not haveimplemented the feature.
Pavel
Reply #2 - Apr 17th, 2007, 6:55am
But why this feature figures in Verilog-AMS Language Reference Manual ?
Reply #3 - Apr 18th, 2007, 8:55am
Parameter arrays are an extension supported in Verilog-AMS.  I'm just saying, a number of AMS simulators are really Verilog-1364 simulators with some amount of the AMS extensions supported, and it looks like yours doesn't have everything you want.
The simulator message does seem to indicate that the vendor knows it's a valid construct, but unsupported.
Pavel
Reply #4 - Apr 19th, 2007, 1:58am
Ok, thanks Geoffrey,
Just for curiosity (if you know) what simulators support all verilog-AMS features/extensions.
I use ncsim (Cadence).
Regards.
Pavel.
Reply #5 - Apr 19th, 2007, 5:24am
To my knowledge, no simulator supports the *full* LRM 2.2 ...
