Aug 15th, 2024, 12:37pm
implement laplace_zp function from measurements (Read 4869 times)
Pavel
Lausanne/Switzerland
Apr 18th, 2007, 4:05am
How to implement laplace_zp function from "pole-zero" analysis.
The output from this analysis is done as table
qfactor      poles (Hz)
0.5            123.6
-0.5           4.5e+6
How to transform this data in paires (real, imaginary), required by laplace_zp function?
Pavel.
Saran
Getting wiser by the
second
Re: implement laplace_zp function from measurement
Reply #1 - Apr 25th, 2007, 8:26am
laplace_zp syntax is  laplace_zp(input, {-z1,0,-z2,0}{-p1,0,-p2,0}) for a transfer function ((1+s/z1)(1+s/z2))/((1+s/p1)(1+s/p2)) where p1,p2,z1,z2 are real poles and zeros. You can get more information from LRM or a basic text book.
However, if you are trying to implement a filter response based on poles and Q-factor values, then wouldn't it be easy to use laplace_nd on the transfer function?
For instance, assume you have a biquad filter that is given by the TF  w^2/(s^2+ s(w/Q)+w^2), w is the pole location(freq) and Q is the Q-factor. Use laplace_nd directly on this function.
I guess what I am trying to say is, depends on what you want to do! Hope this helps.
Pavel
Reply #2 - Apr 26th, 2007, 3:15am
What I want to do is create model in verilog-A of operational amplifier.
I did zero-pole analysis of this OpAmp.
The result of this anaysis is extracted poles and zeros in form of pairs
(qfactor, pole) and conseuntly (qfactor, zero).
How can I use these results to create OpAmp model in verilog-A.
If you understand what I mean, could you, please, create lapalce function for following case:
qfactor      zeros (Hz)
-0.5      1.81E+07
-0.5      1.84E+07
0.5      2.39E+07
-0.5      1.06E+08
qfactor      poles (Hz)
0.5      5.727
0.5      1.24E+07
0.5      1.84E+07
0.5      2.38E+07
-0.5      3.57E+07
Pavel
