Not sure what Krishnap was trying to say, but a transistor level design won't run any quicker in AMS Designer than it would in spectre (unless you're using Ultrasim as the analog solver). If the solver is the same, it will take a similar time.
The benefit of AMS Designer is when you have mixed-signal models in Verilog-AMS or VHDL-AMS, and pure digital parts in Verilog or VHDL. Then you don't need to simulate everything at transistor level any more...
