Jul 21st, 2024, 5:30pm
What is Device checking option in spectre (Read 3277 times)
krishnap
Apr 24th, 2007, 2:24am
In the ADE environment, under simulation tab,
there is a Device checking  tab.
What would be the typical use of this option?
Krishna
Re: What is Device checking option in spectre
Reply #1 - Apr 30th, 2007, 5:31am
It allows you to set up things like "safe operating area" limits on your devices - checking that devices don't exceed a certain current level, for example.
Effectively it allows use of spectre's "assert" statement during the simulation. Look at the documentation on that (spectre -h assert) for more details.
krishnap
Reply #2 - Apr 30th, 2007, 11:34pm
Hi Andrew,
Thanks for the information.
I feel this check is useful, so that it  can notify if the reliability limits
are exceeded.
Krishna
