Oct 14th, 2026, 6:41am
terminal of instance not found on master (Read 5384 times)
Croaker
Apr 25th, 2007, 6:15pm
In my veriloga cell, the syntax is fine but things mysteriously break when I attempt to simulate.
ERROR: netlister : terminal of instance X in cell B, view veriloga : not found on master
My code seems pretty straightforward to me.  It seems like there is a CAD tool problem more than a veriloga code problem...
module x( sig1, sig2 );
 input sig1;
 output sig2;
 electrical sig1, sig2;
 mymod X( sig1, sig2 )
In the real code, the veriloga ports and definitions were generated automatically from the symbol view.  The ports of mymod are inouts.
This one is making me pull my hair out!   Cry
Re: terminal of instance not found on master
Reply #1 - Apr 26th, 2007, 11:54am
It probably won't help but:
1) give the instance of mymod a different name (XX) so it won't be a case-insensitive match for the module it's inside
2) name the port connections of that instance
3) add a semicolon to the end of the line
mymod XX(.sig1(sig1), .sig2(sig2));
Croaker
Reply #2 - Apr 26th, 2007, 3:48pm
Oh, don't scrutinize the syntax too carefully, just trying to convey the idea.
It turns out that it would break or not depending on what order I instantiated the instances.  This makes no sense from a code point-of-view.  Tools misbehave.
chetan
Reply #3 - May 30th, 2007, 8:33am
The names you're trying to use for the module - 'X' and instance - 'x' are both reserved keywords. I bet, that's the reason why the tool is completely confused!
chetan
Reply #4 - May 30th, 2007, 8:36am
Sorry, I should have qualified that these keywords are reserved for the digital part of Verilog-AMS or in Verilog-HDL. The yare reserved as binay/octal/hex digit specification to convey that the value is unknown. Try just changing these names.
