Sep 24th, 2026, 5:19pm
Passing Strings to VerilogA in ADS (Read 3952 times)
makelo
Hillsboro, OR
Apr 27th, 2007, 10:09am
I have a VerilogA function that I use in ADS to read CSV data into the ADS time-domain simulator.  I use a verlogA block to read the data and an ADS "ael" code to create the interface between verilogA and ADS.
This is what I currently use, that works but does not pass the string "File_name":
-----VerilogA-------------
`include "disciplines.vams"
`include "constants.vams"
module Source_IQ_va(n1);
   electrical n1;
   parameter string File_name = "dat2I.tbl";
   parameter real max_time_step = 1.0e-9;
   analog begin
       V(n1) <+ $table_model($abstime,File_name,"1L");
       $bound_step(max_time_step);
---------ADS AEL--------------
/* AEL discription of Source_IQ_va */
create_item("Source_IQ_va", /* Instance name */
     "Verilog-A implementation of CSVsource",  /* Component description */
     "Source_IQ_va",      /* Instance prefix */
     NULL,
     NULL,
     "Source_IQ_va",
     standard_dialog,
     ComponentNetlistFmt,
     "Source_IQ_va",
     ComponentAnnotFmt,
     "SYM_Source_IQ_va",
     no_artwork,
     NULL,
     ITEM_PRIMITIVE_EX,
     create_parm("File_name","Maximium Time Step in BoundStep", PARM_OPTIMIZABLE | PARM_STATISTICAL, "StdFileFormSet", UNITLESS_UNIT, prm("StdForm","1.0")),
     create_parm("max_time_step","Maximium Time Step in BoundStep", PARM_OPTIMIZABLE | PARM_STATISTICAL, "StdFileFormSet", UNITLESS_UNIT, prm("StdForm","1.0"))
My question is how do I change the AEL code to make ADS actually pass a string.  Right now I have to manually change "File_name" in the verilogA for every new simulation.  I think it has something to do with the create_parm function?
Makelo
