Hi, Sheldon,
Quote:1) From the discussion, I can not visualize the issue you are having.
In the past, I have seen tones in the response of a DAC and I
re-created the conditions. Is this frequency spectrum similar to the
the frequency spectrum you are seeing?
I am sorry that I cannot put a waveform here because all the workstations are in a private network in my company. I take a look at my simulation results, they look similar as
smoothed in your graph.
Quote:2) If this frequency spectrum is similar to your frequency spectrum,
then the tones can be eliminated by modifying the input source
being sampled by the ADC.
Do you mean modify the input source to ensure a coherent sampling? Then a sine wave or other periodic signal are sampled at the codes which are evenly distributed. So the quantization noise looks like a white noise in the spectrum, NOT concentrate on some frequency points like
default. The point 3) and 4) are tightly related to 2). Right?
Thank you
Yawei
