Jul 22nd, 2024, 3:28pm
Pages: 1 2
thd function in Calculator (Read 14806 times)
Re: thd function in Calculator
Reply #15 - May 13th, 2007, 7:30pm
Hello, Sheldon,
Do you mean that default is wrong? How do you get smoothed?
Yawei
Reply #16 - May 14th, 2007, 12:00am
Yawei,
  Sorry, to clarify
1) From the discussion, I can not visualize the issue you are having.
   In the past, I have seen tones in the response of a DAC and I
   re-created the conditions. Is this frequency spectrum similar to the
   the frequency spectrum you are seeing?
2) If this frequency spectrum is similar to your frequency spectrum,
   then the tones can be eliminated by modifying the input source
   being sampled by the ADC.
3) My apologizes, the meaning of default and smoothed are not
   clear. The intent was
     - default, the setup I would typically use for testing an ADC
     - smoothed, modified setup for DAC to eliminate concentrating
       quantitazation energy in a few frequency bins.
4) In this case, the input source was changed to make sure that
   that each DAC state gets exercised, or to prevent the quantitazation
   noise from being concentrated in a few frequency bins.
venki_vlsi
warangal
Reply #17 - May 14th, 2007, 10:44pm
If i am not mistaken,,
No of cycles should be odd or prime. IF i am true u  have taken 512 sampling cycles ans since this is even number extra quantization noise is concentrated in  hormonics.hope this true for dac.
s.venkat_nitw
Reply #18 - May 16th, 2007, 2:49am
Hi, Sheldon,
I am sorry that I cannot put a waveform here because all the workstations are in a private network in my company. I take a look at my simulation results, they look similar as smoothed in your graph.
Do you mean modify the input source to ensure a coherent sampling? Then a sine wave or other periodic signal are sampled at the codes which are evenly distributed. So the quantization noise looks like a white noise in the spectrum, NOT concentrate on some frequency points like default. The point 3) and 4) are tightly related to 2). Right?
Thank you
Yawei
Pages: 1 2
