Jul 22nd, 2024, 3:33am
Information needed on "mvarsearch"  feature (Read 1290 times)
kiran123
May 10th, 2007, 6:54am
Hi Experts,
   I have a doubt regarding "mvarsearch" in spectreMDL. if i give my design goal as Trise, Tfall it does a search and gives me final W's of nch and pch transistors ( from below netlist say pch_w1 & nch_w1), but with this feature as it varies the W , will it also considers other parameters like drain, source area ..etc ( i.e as,ad,ps,pd etc) accordingly  to that width keeping constant length
/*************NETLIST**********************/
parameters pch_w1=0.64u
parameters nch_w1=0.58u
subckt INV Y A
M0 Y A VSS VSS nch L=1.3e-07 W=pch_w1 as=2.304e-13 ad=2.304e-13 ps=2e-06 pd=2e-06 nrd=0.280382 nrs=0.280382
M1 Y A VDD VDD pch L=1.3e-07 W=nch_w1 as=1.512e-13 ad=1.512e-13 ps=1.56e-06 pd=1.56e-06 nrd=0.427249 nrs=0.427249
ends INV
if not what modification i should do in MDL to get accounted these for better accuracy
it also uses deltax in option section of  mvarsearch  what is this exactly suppose if i want my end serach result of transistors width as multiples of (say 5E-9  as per desing) to what value i should set it to
in the desrciption it says "numerical difference % of design variables"
can above feature is also be done using "sweep" statement using "mod"  if so what is that pattern ?
Thanks & Best Regards
kiran123
