Oct 2nd, 2026, 9:18pm
Binary counter in VerilogA (Read 676 times)
Vabzter
Sweden
May 18th, 2007, 1:37am
        I am trying to write a 10 bit binary counter in verilogA. I am new to verilogA and so dont know much. Can anyone please let me how to start? My idea is to run a for loop from 0 to 1023 and then convert this to binary. But not sure how to implement this...
Any help on this..
Thanks a lot
Vabzter
Re: Binary counter in VerilogA
Reply #1 - May 18th, 2007, 7:43am
You could start by piecing one together from the DFF model and gates on this site.  See the "Verilog-AMS" in the upper right?  Click there.
Hey! there's actually a counter in theV-AMS section.  Don't know what simulator you are using, nor why the counter model here needs V-AMS rather than just Verilog-A.  But it's probably a reasonable starting point.
makelo
Hillsboro, OR
Reply #2 - May 22nd, 2007, 5:55am
Here is a VerilogA counter that I recently wrote.  I hope it is helpful.
`include "disciplines.vams"
`include "constants.vams"
`define N_Counts 5
`define N_offset 0
// Counter counts N_Counts and provides a pulse every N_offset counts
// Pulse is width of clock
module Counter1(rst,clk,out);
  input rst,clk;
  output out;
  voltage rst,out,clk;
  parameter real max_out = 1.2;
  parameter real edge_time = 0;
  real vout,clk_pulse;
  integer count,clk_shape;
  analog begin
      @(initial_step) begin
         count = -1;
      @(cross(V(rst)-0.6,+1)) begin
         count = -1;
      @(cross(V(clk)-0.6,+1)) begin
         count = count + 1;
         clk_shape = 1;
         if (count > (`N_Counts-1))
               count = 0;
         clk_pulse = (count == `N_offset) ? max_out : 0;
      @(cross(V(clk)-0.6,-1)) begin
         clk_shape = 0;
      V(out) <+ transition(clk_pulse*clk_shape,edge_time,edge_time);
