Jul 19th, 2024, 6:22am
Convergence problem! how to solve it? (Read 4656 times)
savithru
Jun 12th, 2007, 2:59am
hi all,
I am simulating the PLL (trans). But I am unable to do it as I am facing with convergence problem.
Spectre is giving some repost like  "No DC solution found (no convergence)"..
Can you please tell me how to overcome the convergence problem..
Also It will be great if you can tell me  why thse convergence problems comes ..
pls reply
SavithRu
Thanks & Regards
SavithRu
View Profile savithru savithru   IP Logged
Re: Convergence problem! how to solve it?
Reply #1 - Jun 12th, 2007, 4:10am
[quote author=savithru link=1181642349/0#0 date=118164234
Can you please tell me how to overcome the convergence problem.. [/quote]
Read the rest of the message from Spectre, which usually tells you which nodes are causing problems ...
Because you made a mistake in your circuit.  Or you have bad models. Or any of a hundred different reasons, none of which we can even guess at without knowing more about your circuit.  Is it transistor-level or behavioral? Do you have any dependent sources?  Any "bsource" elements?
simon2
Southampton, United Kingdom.
Reply #2 - Sep 23rd, 2007, 3:15am
Hi Geoffrey,
                  this response is probably too late to help you, so I am posting for the benefit of other latecomers ....
You will find under one of the menu lists in the Analog Design Environment window, something called "Analog ...", open this and you will find the simulator convergence settings.  Also, somewhere you will find a menu item called nodeset - think about what voltages should be at strategic nodes like logic totem poles, casccode inputs, diff-pair "tails" and the like, then put in a value on the schematic using the nodeset item.
If you intend to become an analogue designer as a career, I suggest you get hspice - you will find that it is much easier to access these features and can do so with a line or two of text in your scripts.  The downside is, hspice's convergence is not quite as stable on large circuits so requires such intervention more often than spectre, however on circuits that converge in neither simulator, hspice is easier to sort out.
Convergence is a large and complex topic but as an experienced spicer, I can make a few general comments that might help:
-  Homotopy based simulators seem more stable than others
-  Gear method seems better at DC convergence than others, however occasionally
-  Backward-Euler may solve transient convergence faster than others
-  Gmath and Source-ramping techniques seem to overcome convergence issues more efficently.
-  Often a circuit will converge for tran but not DC, so consider using only tran in your design flow (be prepared to do a lot of post simulation processing).
-  Make copious use of 1e12 resistors to define bias points.  Mostly these resistors should be connected to pull the circuits into the "off" state rather the "on" state.
-  Ensure that gmin and gmindc are not too large, that they effect the circuits behaviour (check the run file to see what value the simulator has assigned to these, will give a good indication if the convergence point is correct).
-  try altering PIVREL and PIVTOL from default values; these affect how the matrix is solved and can have an enormous effect on the ability of the simulator to find a solution.
Hope this helps.
Cheers,
           SimonH.
Simon.Harpham@ieee.org
http://www.SiliconDevices.com
simon2
Reply #3 - Sep 23rd, 2007, 3:21am
Additional to my previous post, this subject:
- try partitioning your circuit into sub-circuits, then note the time the simulator takes to converge on these, whilst working on the strategic placement of the 1e12 resistors and the simulator settings, should allow you to build a more stable and robust convergence solution.  You can also then replace difficult sub-circuit netlists with simpler resistor-controlled source descriptions, to allow you to work through the convergence issues.
Cheers,
           SimonH.
Reply #4 - Sep 24th, 2007, 9:11am
simon2 wrote on Sep 23rd, 2007, 3:15am:
Hi Geoffrey,
It was savithru who was having trouble ...
Spectre has a command-line interface as well; don't know what your comment is really trying to say.
Gear is an integration method for transient analysis -- what does this have to do with dc convergence?  I don't think the transient integration method is used for the pseudo-transient.
If it can converge for tran, then you should be able to generate a nodeset for running dc.  Unless your simulator doesn't actually find the time=0 solution (I've heard some of the fast spice simulators don't, they just start running and hope that the problems resolve themselves during the transient).
