Mosieur_Oiso
Hi all, Is there a way to insert measurement equations in Spectre? (equations based on signals or parameters from a schematic, like MeasEqn of ADS) To illustrate my problem, let me show you the following very basic example I tried: 1/ I wrote a simple equation in a text file, saved as function_1.scs:
simulator lang=spectre real f_1(real a) { return 2*a; }
2/ I included and enabled /home/.../function_1.scs in ADE->Setup->Model Libraries...
3/ I added the following in ADE Outputs: Name: p_f_1 Expression: p_f_1 = f_1(VF("/V_1")) [ V_1 is a net in my schematic ] and set Plotted/Evaluated
4/ I launched an analysis (ac in this case)
The simulation completes normally but I cannot get the p_f_1 output, and in the icfb window, I get the following errors: *Error* Evaluating expression ((p_f_1 = (f_1 VF("/V_1")))). [the syntax of the expression in Outputs is then changed to what is displayed here] *Error* ("eval" 164 t nil ("*Error* eval: undefined function" f_1))
Where am I wrong? Again, this is a very simple example I take to show the problem. Actually, I am an ADS user switching to Spectre, and I basically want to know if I can define equations in Spectre like I used to do in ADS. Thanks for help, Mosieur_Oiso.
