Jul 20th, 2024, 10:17am
How to perform Nested Sweep (Read 1795 times)
kiran123
Jun 27th, 2007, 12:15am
Hi Experts,
       How to declare  nested sweep statement in spectre , like suppose i wanted to see graph between V1 Vs V2 Vs V3 simultenously in the same plot
In SPICE it is like
    .DC V1  1 5 0.1   V2  1 5 0.1  V3  1 5 0.1
similarly is there any way to do this in spectre ?
Thanks & Regards
Kiran
aamar
Re: How to perform Nested Sweep
Reply #1 - Jun 29th, 2007, 8:38am
Hallo,
Do you have the Analog design environment?
you should set a single sweep, and use the other two sources (i.e. V2 and V3 as parameters) and then define parameteric sweeps.
for different variants of plots you can use the function "value" in the calculator.
but take care for the step you are using you will have to run the simulation 40x40 times which is a large number.
best regards,
aamar
kiran123
Reply #2 - Jul 2nd, 2007, 11:25pm
aamar wrote on Jun 29th, 2007, 8:38am:
Hallo,
best regards,
aamar
 i don't have ADE  :(  that's why looking for deck statement
Kiran
aamar
Reply #3 - Jul 4th, 2007, 2:57am
Hallo Kiran,
Although  I am not expert in Spectre Syntax. I use the ADE always, and without reading the manual, I think you should have a look on it too. But my first impression that there is no such a syntax becuase if it is possible it should be possible through the ADE. That's why I tried such a case like the one you are asking about and printed the OCEAN script from the parameteric analysis tool and pasted it here, may be it can help.
ocnWaveformTool( 'wavescan )
simulator( 'spectre )
design(       "./spectre/schematic/netlist/netlist")
resultsDir( "./spectre/schematic" )
modelFile(
   '("./spectre/c35/mcparams.scs" "")
   '("./spectre/c35/cmos53.scs" "cmostm")
   '("./spectre/c35/res.scs" "restm")
   '("./spectre/c35/cap.scs" "captm")
   '("./spectre/c35/bip.scs" "biptm")
   '("./spectre/c35/ind.scs" "indtm")
analysis('dc ?param "vsweep"  ?start "0"  ?stop "3"  )
desVar(        "vsweep" 0      )
desVar(        "vgs_nmos_param" 0.6      )
desVar(        "vds_nmos_param" 0      )
desVar(        "l" 0.35u      )
save( 'i "/MN0/D" "/MN1/D" )
temp( 27 )
paramAnalysis("vgs_nmos_param" ?values '(0 0.75 1.5 2.25 3 )
 paramAnalysis("vds_nmos_param" ?values '(0 0.75 1.5 2.25 3 )
paramRun()
Best regards,
aamar
Reply #4 - Jul 5th, 2007, 6:42am
kiran123 wrote on Jun 27th, 2007, 12:15am:
Hi Experts,
In SPICE it is like
You could probably do this with the alter command, at least in terms of getting the sims run; then it would depend on your waveform viewer how easy it is to view them simultaneously.  Also, it will be a nuisance to write all the alter commands to run the sweeps; you've got 51*51 sweeps there, don't you?  So I hope a cadence expert can help with the paramAnalysis statements.
Reply #5 - Aug 27th, 2007, 2:24pm
I've got an example somewhere (not at work at the moment) - but the easiest thing is to read the help on the "sweep" analysis in spectre. See "spectre -h sweep". You'll do something of this form:
sweepv1 sweep param=v1 start=1 stop=5 step=1 {
  sweepv2 sweep param=v2 start=1 stop=5 step=1 {
    dc dc param=v3 start=1 stop=5 step=1
(the above is just off the top of my head, so may contain mistakes).
John O Donovan
San Jose, CA
Reply #6 - Aug 28th, 2007, 4:56am
Andrew,
It should probably be the following. The inner sweep in the first in the .DC, and it should be dev=v1 instead of param=v1
sweepv1 sweep dev=v3 param=dc start=1 stop=5 step=1 {
 sweepv2 sweep dev=v2 param=dc start=1 stop=5 step=1 {
   dc dc dev=v1 param=dc start=1 stop=5 step=1
The param=dc is probably not necessary since the default sweep parameter for a vsource is the dc parameter.
 John
Reply #7 - Sep 2nd, 2007, 1:00pm
John, I was actually assuming that v1, v2, v3 were global parameters, but if instead it was the dc parameter of a voltage source that was being varied, then you're quite correct, of course...
