Jul 16th, 2024, 10:19pm
simulate Fractional-N PLL by Cadence AMS designer (Read 2899 times)
SemiLeon
Jul 13th, 2007, 8:10am
Hi, All,
I found a problem in the simulation of a Delta-Sigma fractional-N PLL by cadence AMS designer. I construct the PLL by the blocks in different forms:
(1) PFD, charge pump and loop filter: Spectre netlist
(2) VCO: verilog-A model
(3) Feedback divider and Delta-Sigma modulator: Verilog-HDL
The Delta-Sigma modulator output a divider ratio at each reference clock, and the long term average is the wanted fractional divider ratio. But in the simulation, I can't see the "averaging" effect. The PLL works as a integer-N PLL with different divider ratio at each reference clock. I also use the FFT to observe the spectrum of the output, but still hard to find out a major tone.
Is the AMS feasible for such simulation. Please give me some advise about this issue.
Thanks and Best Regards.
Leon
Marq Kole
Hmmm. That's
weird...
Eindhoven, The Netherlands
Re: simulate Fractional-N PLL by Cadence AMS desig
Reply #1 - Jul 24th, 2007, 12:05am
In general, AMS would be perfectly suited for these kinds of systems as you have nearly all the behavior you need without the simulation cost of a transistor-level model.
Although I'm no expert on these things, if the VCO (= PLL output) reacts that quickly to changes as you describe, it sounds like the loop filter is not doing its job. The rate of change in the divider should be higher than the loop filter bandwidth.
