SemiLeon
Hi, All, I found a problem in the simulation of a Delta-Sigma fractional-N PLL by cadence AMS designer. I construct the PLL by the blocks in different forms: (1) PFD, charge pump and loop filter: Spectre netlist (2) VCO: verilog-A model (3) Feedback divider and Delta-Sigma modulator: Verilog-HDL The Delta-Sigma modulator output a divider ratio at each reference clock, and the long term average is the wanted fractional divider ratio. But in the simulation, I can't see the "averaging" effect. The PLL works as a integer-N PLL with different divider ratio at each reference clock. I also use the FFT to observe the spectrum of the output, but still hard to find out a major tone. Is the AMS feasible for such simulation. Please give me some advise about this issue.
Thanks and Best Regards.
Leon
