Aug 15th, 2024, 12:36pm
AC Analysis of Verilog-A Module (Read 8270 times)
Nano_Model
Jul 13th, 2007, 2:58pm
I have a complicated 4-terminal device module written in Verilog-A. It works for DC and transient analyzes. However, when I use it to run AC analysis, what I get from the output are all unexpected zeros. What's a possible reason for this?
I read previous post saying that the simulator builds an equivalent small-signal circuit based on DC information it has. How does it actually work? Like...does it build a typical hybrid-pi model, a T-model? or? Can I "probe" the small-signal capacitances calculated by the simulator in this case? Give the complexity of my module, I wonder how can the simulator build a SS circuit for it. Does it just treat my module as a black-box and probe its terminal behavior?
Thanks a lot,
Nanodel
Re: AC Analysis of Verilog-A Module
Reply #1 - Jul 13th, 2007, 4:39pm
Did you provide a small-signal stimulus?
Nano_Model
Reply #2 - Jul 15th, 2007, 1:47pm
Yes, I used (in SPICE) .ac analysis...
Reply #3 - Jul 16th, 2007, 4:46am
You didn't answer Ken's question.  Having an ac analysis doesn't mean that there's actually an ac source (small-signal stimulus) in the circuit.  If you don't have a stimulus, then you'll always get zero output.
The following is a 5V dc source *with* a magnitude=1 small-signal stimulus.
V1 1 0 5 ac 1
The simulator takes the (symbolic) derivatives of all the expressions you used in your module and uses them to determine the ac response.  It needs the derivatives anyway for using Newton's method to solve the dc operating point.
Nano_Model
Reply #4 - Jul 16th, 2007, 10:56am
Thanks Geoffrey. Yes, I did include an ac stimulus like what you've said. Nevertheless, I still got 0.0 as my output.
Now from your answer, I have another question. Is the simulator always able to compute the symbolic derivatives of any expression? My drain current expression is not analytical. It involves solving a self-consistent equation iteratively. So, in this case, I wonder how the simulator computes the derivatives and linearizes my module.? Huh
Reply #5 - Jul 19th, 2007, 4:44am
I believe the simulator is always able to compute the symbolic derivative.  Even if you have an iterative solution, it's all composed of assignments:
//dx_dv = dx0_dv;
x = x0;
for (...) begin
// dx_dv = dx_dv + dupdate_dv;
x = x + update;
where the //commented lines are added by the compiler generating the C code from the Verilog-A.
Nano_Model
Reply #6 - Jul 21st, 2007, 10:44am
Cool.
Are there any manuals/books/documents for me to understand how the simulator works? Like...how the verilogA code is converted to C...and how the simulator runs various analysis... Smiley
Reply #7 - Jul 27th, 2007, 6:36am
I don't think there are any books (nor even papers) on how Verilog-A is converted to C.  There might be something about how Verilog-A equations are translated to equations and unknowns in the simulator in "The Designer's Guide to Verilog-AMS."  (Chapter 3, Analog Modeling, Section 2.1, Conservative Systems)
As for how the simulator runs analyses, "The Designer's Guide to Spice & Spectre" is probably going to cover it for you.
If you click "Books" above, you can get to some links that will chip a few cents (maybe a buck or two?) back to help support this site.
For your actual problem: can you try writing an explicit function for the drain current (maybe the "initial guess" for the iteration)?
Also, check your if() statements carefully.  Sometimes people things like:
if (x < -100)
 Iout = 0;
else
 Iout = f(x);
forgetting that Iout = 0 also means dIout/dx = 0, and this would give you a zero output in ac.
