Jul 17th, 2024, 10:37am
"phase.vams", what is it? (Read 2057 times)
feihudui
Jul 18th, 2007, 1:34am
I tried to simulate the phase noise of the VCO using the code in the paper "predicting the phase noise and jitter of PLL-Based Frequency Synthesizers". But i had a problem. The AMS simulator doesn't know, where is the file "phase.vams". I cannot find it also. Can you tell me, where can i get or find it? Thanks.
ACWWong
Oxford, UK
Re: "phase.vams", what is it?
Reply #1 - Jul 18th, 2007, 2:48am
did you read p12 ? you need to define the discipline phase yourself. if you use the other listings then you'll have to do the definition is a file called phase.vams
