Jul 19th, 2024, 8:30pm
Problem in accessing hierarchy with OCEAN (Read 2370 times)
subho
Jul 24th, 2007, 12:44am
Hi All,
              I have been trying to plot the transient waveform for current using the following ocean script:
; set the temperature
option(      'temp  "25" )
; save all nets and currents
save('all)
saveOption('useprobes "yes" ?currents "all" )
save('alli )
keep('alli )
resultsDir( "./psf/tran" )
analysis('tran ?start 0 ?stop "80u")
run()
resultsDir("./psf/tran");
selectResult('tran);
newWindow()
ocnPrint( i("/Iin.in"));
delete('analysis 'tran)
; end of file
The error is shown as:
The output 'Iin.in' you selected does not exist.  Type
         outputs() to see the list of available outputs or type
         help('i) for more information on the 'i' command.
I find Iin.in existing in the set of  outputs however.  What can be the possible problem ? can this arise because it fails to explore the hierarchy? I tried with plotting voltage down hierarchy and it flashed similar error....can anybody help?
haikom
Re: Problem in accessing hierarchy with OCEAN
Reply #1 - Aug 16th, 2007, 4:35am
please enter "outputs" in the CIW and see whether the requested current is saved. Maybe you have to increase the subcircuit probe level (which define the hierachical level where currents are saved).
haikom
View Profile haikomo   IP Logged
