nishanis
Hello, I have a switch model for nfet and pfet. All combinational gates work fine with those models. I was modeling a latch with the that model. But it wont store a value. So i added capacitor between gate and source and capacitor between source and drain. Still the result is always same it 1.8v irrespective of the input. I(G,S) <+ c1 * ddt(V(G,S)); if (V(G) >= 0.9) Rch = Roff ; else Rch = Ron ; I(S,D) <+ c1 * ddt(V(S,D)); a = transition(Rch,0,0,0); V(S,D) <+ I(S,D) * a; This is for nfet. Can you suggest why is it not working? the c1 value i am using is 1fF as my ron =100 ohms. hoping to get the solution to work with this. thanks
