Aug 15th, 2024, 12:31pm
Skipping first few clock cycles for cross statemen (Read 2847 times)
sylak
Silicon valley
Jul 25th, 2007, 3:07pm
I am writing a code for a counter and am using @cross statement to begin my count. But I wasnt to skip first few clcok cycles before I start my counter. Is there  a way to do this trick?
kamath
Re: Skipping first few clock cycles for cross stat
Reply #1 - Jul 25th, 2007, 10:52pm
hai,
y dont u include a delay buffer for the clock so that the number of clocks to be skipped can be calculated and so much delay given...
hope this works,ne other solution do tell me.....
bye
Marq Kole
Hmmm. That's
weird...
Eindhoven, The Netherlands
Reply #2 - Jul 26th, 2007, 12:16am
Use an integer variable active that you set/unset based on any condition you require, and have the counter only count when active is set.
parameter real tstart = 1u from [0:inf);
integer active;
analog begin
  if ($abstime > tstart)
    active = 1;
  @(cross(V(in)-0.5, +1))
    if (active)
	count = count + 1;
The code that sets active can be anything, also a number of counts made, a signal on a terminal, etc.
sylak
Silicon valley
Reply #3 - Jul 26th, 2007, 1:37pm
Thanks Marq..That helped
