Jul 20th, 2024, 12:22am
OCEAN for HSPICE ? (Read 3204 times)
richard88
OCEAN for HSPICE ?
Jul 27th, 2007, 3:36pm
 I wish to use HSPICE as my simulator instead of spectre, may I know if I can still use my OCEAN script to run on HSPICE simulator ?
Thanks.
richard88
Re: OCEAN for HSPICE ?
Reply #1 - Jul 29th, 2007, 3:17pm
Just to clarify that I'm still using the Cadence Analog Design Environment to run the sim but using HSPICE simulator.
richard88 wrote on Jul 27th, 2007, 3:36pm:
Thanks.
Reply #2 - Aug 27th, 2007, 2:13pm
Yes. You can. This should work if you're using hspiceD or the older (obsolete) hspiceS interface.
