Jul 20th, 2024, 10:16am
time-domain noise analysis in switched capacitor (Read 9857 times)
hpham
Jul 30th, 2007, 11:39am
I tried to use the time-domain noise feature of spectreRF for my switched capacitor amplifier design. I'm not sure how to select noise skip count and number of time poinst to have the accurate output noise density. I tried the sampled noise at only a single point (t=0) and vary maxsideband parameter and I already see the big difference for maxsideband = 20 & 50 case.
I wonder for the case of amplifier, sampled noise at a single time point represent the accurate output noise density of a circuit OR i should choose more time points (at least two --> peak to peak voltage time points) ?? and how can I do that??
I've read the cadence document : Simulating switched-capacitor filters with SpectreRF (version 6c, 28 July 2006)
best regards,
ha
horizon
Re: time-domain noise analysis in switched capacit
Reply #1 - Jul 31st, 2007, 6:01am
Hi hpham,
I suppose I am going to face the same problem as you as  I am designing the same circuit.
At the moment I still wonder which simulator between spectre and eldo is the best to do this.
I read " simulating switched capacitor filters with spectre RF"  and also "device noise simulation of sigma delta modulator".
The spectre way of doing the simulation is not completly clear to me .
Did you try to do the simulation with eldo and its noisetran analysis?
I think I am going to test spectre RF on an ideal amplifier using ideal switch and ideal capacitor in order to check what is the output noise.
have a nice day
 horizon
Reply #2 - Aug 3rd, 2007, 9:10pm
Ha,
  A comment on the setting of maxsidebands, what is the noise
bandwidth of your circuit? You need to set maxsidebands so that
all noise or at least the noise out to the noise bandwidth is
included in the pnoise analysis. From your description, the circuit
has a wide noise bandwidth so using 20 sidebands does not fold
all the noise down. By increasing the maxsidebands to 50 more
noise is folded down and the noise increases. Evaluate the noise
bandwidth of the circuit and then set the number of maxsidebands.
hpham
Reply #3 - Aug 7th, 2007, 10:18am
Sheldon,
Thanks for your reply. I though I set maxac freq big enough ( = 100M). More information about my setup : input freq = 12.5K, sampling clock = 200KHz, Bandwidth = 100KHz, amplifier's voltage gain = 72dB ( 3 stages in cascade, each = 24dB) . Input capacitor = 64pF, feedback capacitor = 4pF. When using maxsideband = 20, output noise density = 50.7nV2/Hz. msb = 50 , output noise = 87.7nV2/Hz. That's for the case of one single time point. I am thinking about choosing 2 time points to represent the peaks of output voltage, but i don't know how.
Horizon,
Thanks for your reply. I don't have access to Eldo.
best regards,
ha
horizon
Reply #4 - Aug 30th, 2007, 4:47am
Hi everybody,
At the moment I designed my circuit using spectre... but for the noise analysis , I used eldo (I am lucky guy, I have access to eldo and spectre)
The results seems to be realistic.
Nevertheless, It would be nice for me to use spectre also for the noise analysis.
I don't understand how to have a comparable result with eldo.
What I am doing with eldo:
.TRAN 10p 100n
.NOISETRAN FMIN=0 FMAX=5G NBRUN=20 MRUN
My clock is working at 20Mhz, for the noisetran analysis, the first cycle is not measured.
The result I measure is the rms noise when the data is sampled (let say I measure my noise at 100ns )
for example, I get a noise of 200uVrms
Does somebody know how to do something comparable with spectre ?
the spectre simulation I did gave different results. Somebody has a idea of the setting I should use ?
Thank you very much
have a nice day
                 Horizon
Reply #5 - Sep 6th, 2007, 6:41am
Ha,
 I don't understand your comments about selecting two points
at the peaks of the output voltage. Does your testbench have
an input signal? Shouldn't the input be grounded when simulating
noise?
  It is easier for me to think about this in terms of S/H behavior so
I will describe the behavior that way. My understanding is that
you need to evaluate two conditions:
a) the sampling mode noise, measured at the instant the sampling
   when the S/H switches to hold mode
b) the hold mode noise, measured at the time when the next
   stage samples the output
For a S/H operating at 10MHz and a 50% duty cycle, I would
select two time points,  50ns and 99ns.
For a test circuit I built, the sample noise 1.25mVrms and the hold
noise was 3.45mVrms so the total is 3.67mVrms from PNOISE. In
my case the op-amp and sampling circuit are wideband so I needed
to use a lot of sidebands, ~100.
                                                        Hope this helps,
xiaodu2001
Reply #6 - Nov 13th, 2008, 7:15pm
hpham wrote on Aug 7th, 2007, 10:18am:
Sheldon,
Horizon,
best regards,
ha
may i  ask u a  question ?
in the simulation u took above ,what is the parameter "stop" in pnoise analysis u choose?
this is the problem bothering me so much these days.thanks a lot!
manodipan
Re: time-domain noise analysis in switched capacitor
Reply #7 - Nov 14th, 2008, 2:27am
Hi guys,
I am also designing some switched capacitor filters and facing the same problem...i am following Ken's tutorial on SC filter simulation in Spectre RF...For time domain noise analysis what i do is,i make input dc voltage source zero and then no input source is selected ,noise type is selected as time domain....but it does'nt work at all???
also i am confused abt stop freq??
