Aug 15th, 2024, 12:02pm
oscilllator (Read 1530 times)
kamath
oscilllator
Aug 08th, 2007, 4:38am
hai,
I am trying to model an oscillator.following is the code,please tell me if i am right also is there any limitation for it....if so please specify.because when i introduce it in acircuit which has clocked comparators and the output of the oscillator forms the clock ,i am getting wrong results
// VerilogA for san, vericomp, veriloga
`include "constants.vams"
`include "disciplines.vams"
module oscf(out, cont);
input cont;
output out ;
electrical out, cont ;
parameter real vl=0;            // high output voltage
parameter real vh=1.5;            // low output voltage
//parameter real tt=0.01/freq from (0:inf);// transition time //of output
parameter real vtrans = 0.1 ;
integer n ;
real next ;
real freq ;
analog begin
@(initial_step) begin
     freq = 500000 ;
     next = 0.5/freq + $abstime;
@(timer(next)) begin
     n = !n ;
     next = next + 0.5/freq ;
   V(out) <+ transition(n ? vl : vh, 0, 100p);
@(cross(V(out) - vtrans, 1 ))
if(V(cont) > 1000u) begin
freq =  freq - 50000;
else if  (V(cont) < 1000u) begin
freq =  freq + 50000;
else begin
boe
Re: oscilllator
Reply #1 - Aug 8th, 2007, 4:59am
Hi kamath,
Do you really want to change the frequency at every rising edge of V(out), depending on whether V(cont) is below or above 1mV!?
And I'd recommend initializing n.
BOE
And (BWT) using vl for the high output voltage is IMO a quite unusual choice....
