Aug 15th, 2024, 12:15pm
Opening an external program through cadence (Read 1753 times)
ghad
Aug 09th, 2007, 11:39am
I am using verilogA under cadence. But I need to run an outside .exe program (or a Matlab .m file) in the background. Can it be done through cadence ( can i open the outside program by using a function in cadence (as in skill) or in verilogA?)
Thank you.
Best regards.
boe
Re: Opening an external program through cadence
Reply #1 - Aug 10th, 2007, 3:58am
Hi ghad,
You can use the SKILL command system("cmd") for this.
BOE
ghad
Reply #2 - Aug 13th, 2007, 9:42am
Thanks for your message, but I wasn't able to find any tutorial or manual about how using the CIW in cadence to see how to use the "cmd".
If let's say, i want to open the following: "/home/program.exe"
What would be the syntax used?
Thank you for your time,
Best regards,
Ghad
boe
Reply #3 - Aug 13th, 2007, 9:55am
Hi Ghad,
You'd use the SKILL- Code:
system("/home/program.exe")
Hope this helps...
BOE
