Aug 15th, 2024, 6:32pm
cap model (Read 2228 times)
grosser
cap model
Aug 23rd, 2007, 6:39am
hello
i've got one problem in modelling capacitor
i wrote
I(vp,vn) <+ ddt(c*V(vp,vn))
but c=25*limexp(-23.3*V(vin_p,vin_n))
the error message is
           line 16: Error: An operand dependent on the output of a dot() operator
       (dynamic expression) can not be used in a multiplication operation when
       the other operand is dependent on a probe or the simulation time.
       Consider using a node to hold the dynamic expression and probe this
       node in the multiplication operation.
       See also the section of the SpectreHDL reference manual describing
       "Time Derivative Operator".
i am beginer and don't understand the proposed solution starting with consider
can you explain me how to fix it?
regards
Frank Wiedmann
Munich, Germany
Re: cap model
Reply #1 - Aug 23rd, 2007, 6:45am
You can find an example for a varactor model in Listing 1 of http://www.designers-guide.org/Modeling/varactors.pdf. It's probably the multiplication inside the ddt() function that causes your problem.
grosser
Re: cap model
Reply #2 - Aug 23rd, 2007, 7:23am
right, thank you
