Jul 16th, 2024, 8:24pm
Test bench design - tasks (Read 6713 times)
jjrael
Aug 24th, 2007, 10:09am
All,
I am starting to write verilogAMS test benches to verify the functionality of my schematics and models. I want to reuse my code so I am trying to fold them into a task. However, I am running into problems when I try to pass a analog signal to the task. For example I have a task call e_20MHz and I pass it an "analog" port:
e_20MHz(I0.X1);
My task is define:
  task e_20MHz;
     input in1;
     real  in1;
     real         tp0;
     real         tp1;
     real         tp_val;
     begin
        tp0 = V(in1);
        #25 tp1 = V(in1);
        tp_val = (tp0 - tp1)/2.0;
        $fdisplay(d_fd,"%7.3f\tE@20MHz XO\t%5.2g", $abstime*1e6, tp_val);
  endtask // e_20MHz
When I run, I get this error:
verilog.vams
        tp0 = V(in1);
ncvlog: *E,EXPBON (/xxx/verilog.vams,87|19):  Expecting only branch or node type arguments [5.2(AMSLRM)].
        #25 tp1 = V(in1);
ncvlog: *E,EXPBON (/xxx/verilog.vams,88|23):  Expecting only branch or node type arguments [5.2(AMSLRM)].
       module xxx.v_XO2:verilogams
               errors: 2, warnings: 0
Any ideas?
Mighty Mouse
Here I come to save
the day!
Fantasyland
Re: Test bench design - tasks
Reply #1 - Aug 24th, 2007, 10:57am
Have you tried declaring in1 as being electrical? That seems to be what is missing.
-MM
jjrael
Reply #2 - Aug 24th, 2007, 11:04am
ncvlog did not like that at all:
     electrical in1;
ncvlog: *E,MISEXX (/xxx/verilog.vams,80|19): expecting an '=' or '<=' sign in an assignment [9.2(IEEE)].
jr
Reply #3 - Aug 27th, 2007, 5:20am
Are you `including discipline.vams (or .h) to get the definition of electrical?
Also, I'm thinking that V() isn't allowed in tasks (I know it's not allowed in functions).  You need a module with an electrical port, and then have a real variable Vin1 = V(in1)  that gets passed to the task.  In any case, you shouldn't have real and electrical applied to the same input.
