jjrael
All,
I am starting to write verilogAMS test benches to verify the functionality of my schematics and models. I want to reuse my code so I am trying to fold them into a task. However, I am running into problems when I try to pass a analog signal to the task. For example I have a task call e_20MHz and I pass it an "analog" port:
e_20MHz(I0.X1);
My task is define:
task e_20MHz; input in1; real in1;
real tp0; real tp1; real tp_val; begin tp0 = V(in1); #25 tp1 = V(in1); tp_val = (tp0 - tp1)/2.0; $fdisplay(d_fd,"%7.3f\tE@20MHz XO\t%5.2g", $abstime*1e6, tp_val); end endtask // e_20MHz
When I run, I get this error:
verilog.vams tp0 = V(in1); | ncvlog: *E,EXPBON (/xxx/verilog.vams,87|19): Expecting only branch or node type arguments [5.2(AMSLRM)]. #25 tp1 = V(in1); | ncvlog: *E,EXPBON (/xxx/verilog.vams,88|23): Expecting only branch or node type arguments [5.2(AMSLRM)]. module xxx.v_XO2:verilogams errors: 2, warnings: 0
Any ideas?
