Jul 20th, 2024, 8:16am
PSS for characterising switch mode amplifiers? (Read 3335 times)
Prabhu
Aug 27th, 2007, 3:21am
Is PSS analysis suitable for analysing switch mode amplifiers like class D PAs?
Raja
Re: PSS for characterising switch mode amplifiers?
Reply #1 - Aug 27th, 2007, 10:03am
PSS and its small-signal minion (PAC, PXF, PSTB, etc) can be used on switching amplifiers as well as switching regulators. PAC & PXF can be used to find things like small-signal output impedance and supply rejection. PSTB can be used to measure the loop gain of the amplifier. PNoise can be used to determine the noise performance. One can also use QPSS to measure distortion and Envelope Following to speed up a long transient analysis.
What is it that you are trying to measure?
Prabhu
Reply #2 - Aug 28th, 2007, 3:03am
Thanks for the reply Ken.
I need to characterise the distortion and stability performance of a switching (pwm) amplifier in feedback.
I was not sure whether to use PSS since it is not recommended for a similar delta-sigma modulator system.
Raja
Reply #3 - Aug 28th, 2007, 2:04pm
A prerequisite for use of PSS is that your circuit have a periodic solution. Sigma-Delta converters do not have periodic solutions. If your amplifier uses delta-sigma modulation then you probably cannot use PSS.
For stability use PSS/PSTB. For distortion use QPSS/QPAC.
