Oct 17th, 2026, 11:33pm
Syntax error while using genvar (Read 3342 times)
magathi
Utah
Aug 31st, 2007, 9:30am
Iam just tring to implement the adc example in the 'designers guide to verilog ams'
This is part of the code Iam using....
parameter integer bits = 8 from [1:24];
genvar i;
integer g;
analog begin
     @(cross(V(clk)-thresh,+1) or initial_step) begin
     sample =V(in);
     midpoint = fullscale/2.0;
     for (g=bits-1; g>=0; g=g-1)begin
           if (sample>midpoint) begin
             result[g]=vdd;
             sample = sample-midpoint;
           else begin
             result[g]=0.0;
           sample =2.0*sample;
     end //end cross
     for (i=0;i<bits; i= i+1)
     begin
     V(out[i])<+transition(result[i],td,tt);
     end //analog end
when I try simulating this using  AMS (Analog design environment XL) this is the error I get....
Error found by spectre.
   Problem found in instance `pip_adc_top.I9' of module `pip_adc'
ncelab: *E,SYERROR (/home/mjayara/test/pip_adc_top/adexl/results/data/Interactive.44/1/test:pip_adc
_top:1/netlist/ihnl/test/pip_adc/verilogams/verilog.vams,39|11): In for-loop control, genvar expression can only consists of integer constant or other unrolled genvar variables expression.
Could someone help me out.... As far as I see it Iam using integer constants in the genvar expression......
Marq Kole
Hmmm. That's
weird...
Eindhoven, The Netherlands
Re: Syntax error while using genvar
Reply #1 - Sep 26th, 2007, 12:49am
Is the analog for-loop allowed to depend on a parameter in the version of AMS Designer you are using? You could try to replace the "bits" in the for-loop control by an integer constant. Is the "out" array terminal also dependent on "bits"? If not, try to use the same value here. In the past I've used macro variables to get around this limitation in Verilog-A/AMS compilers, i.e. `BITS.
Marq
